jds97Wrangler
- Oct 19, 2008
- Mccleansville, NC
I am baffled with my TJ it has a 4" in rough country lift and an 8.8 LS other then that it is a stock 4 cylinder 5 speed.
The problem I am having is when I take off in first gear I get 3 or 4 loud clunks like something is loose or shifting. It only does it on take off in first gear, all other shifts are fine no vibrations nothing. It I take off real slow it does not do it. I have pulled both front and rear axles and check all bushings and re torqued every bolt on the suspension. It sounds like it is coming front the center of the jeep.
I even adjusted the pinion angle because it appeared like maybe I was getting some axle wrap on take off (I know that is very difficult with a coil for link suspension but I was looking for anything) and the rear drive shaft might be binding but nothing has taken care of it, it does it in 4x4 and 2 wheel drive.
Anyone have any suggestions on what I should check next?
