Help with hummer wheels...
bbareconstruction
wilkesboro
I just took a set apart to seperate the iroks off for new tires...
Does the two piece mag center section of the rim have to be used for the wheel to work? How hard are they to reassemble?
I had to cut mine down width wise and had to replace a few studs and nuts my opinion pain in the ass unless u have a good impact and air compressor
I done two of mine by hand one of the twice it wouldn't seal due to the width of the mag
The mag center is for the beadlocks. You can't air down unless you install those, because the 16.5" wheels don't have a 90*/safety bead like 15s, 16s, or 17s do.
Hummer wheels are stupid easy to assemble. The only problem might be if you have a set with the five-sided nuts on them. Hell of a lot easier than a 32-bolt AL beadlock.
Hummer wheels? Isn't that what they call roller skates on a hooker?
