help with k5
I've got 6" and a 1" body lift from ORD.. fit 37's with minimal trimming....
But yeah, lower your Tcase, most GM's have the spacers already there. Look at the cross member where it's bolted to the frame. On the top of the frame you'll see them.. the bolts are extra long the the spacers are on top of the frame between the nut and the frame rail. Just move those spacers to in between the frame and the crossmember and you're all set. And your driveshafts will work alright with a 6" lift, until you get real crazy. I ended up breaking a Ujoint after about 2 years of use (even with a 14bff in the back)
thanks man ill try that out
