i hate jasper transmissions. they suck, and do nothing but piss off real transmission builders.
No offense but if your going bash a competitor it is pretty childish just to say they suck and not back it up with something substantial.
I can not speak to your abilities as a transmission builder because I have never done business with you. You may very well be one of the few who can rebuild a transmission. However I can speak to my experience with other so called reputable tranmission builders and it sucked. Both times I had a transmission rebuilt they failed with in 2 months of being rebuilt. That was with two differnet vehicles one a 99 blazer and the other a 98 dodge 4x4.
I sold the blazer after putting a junk yard tranny in it. The 98 dodge 4x4 I did some research and found that Jasper advertised they fixed dodges screw up in the mid 90's tranny. This fix included
**JASPER installs a line to the pressure regulator valve to supply
more fluid to the lube circuit than the original.
1. For increased durability, JASPER has upgraded the overdrive
planetary to a 5 pinion planet.
2. The direct clutch thrust plate has been updated for longer clutch
life.
3. The waffle plate has been removed for a better third to fourth
shift.
4. The overdrive clutch has been updated to a 5 plate clutch, and the
direct clutch has been updated to an 8 plate clutch. This was done
for increased torque capacity.
5. NEW billet low/reverse piston & steel reaction pin are installed
to upgrade a weak OEM design. This upgrade prevents piston/pin
breakage and utilizes an O-ring to prevent pressure loss.
I'm sure you do all these things to the Dodge 46RH trans and not just a standard rebuild as the first shop did for my transmission that allowed it to run for less 3000 miles before it died again. I ran the Jasper trans for another 100,000 miles and it was still pulling strong when I sold the truck. Now if you’ve had a different experience with Jasper please share.
