I drove and towed with my 2006 for 167k before I sold it. Solid truck, mine was 2wd 2500 CC LB so it did not have the ball joint issues common with the front suspension. 2007 has the multi-cylinder shutoff for highway cruising and should do better than the 13.5 average MPG I used to see. Highway cruising steady I could get in the 15s once in a while. The truck towed great, the 545RFE was great (I changed fluid every 30k), it just had a quirk due to the funky dual ration 2nd gears that it was better pulling up grades with Tow-Haul mode disabled. I would recommend one to anybody that could stomach the fuel mileage. Follow the maintenance guide in the book but change the trans fluid more often. I probably towed 30+k miles with that truck, pulling small and mid-size enclosed trailers and a car hauler for wheeling trips.
