High Steer - Not high enough
Futbalfantic
Charlotte
Vech. 94 YJ
SOA w/ EB dana 44
Leafs started to sag so I added a leaf to the pack. When doing this only allotted 1/16" or so of clearence between the leaf pack and the tie rod. The tierod is a rescued from a donor vech. which is the type that has the drag link built in and a collar on the other for adjustment.
My question:
What is the height between the top of the high steer arm and the bottem of the "tube" for the tie rod. (assuming Right Hand ES2234R and Left Hand ES2010L are used)
Is there a "high clearence" tie-rod end out there that will fit?
I used heim joints instead of TRE's/ I added a spacer to the top of the high steer arm for both the drag link and the tie rod. I also used a 4" drop pitman arm. All this combo brought my steering geometry in line.
