ckruzer
Infidel
- Jul 2, 2015
- asheville nc
In all my "research" of what to do and not to do, I have never come across this thought pattern. Would like yalls input, just to make sure I havent missed anything. Thanks guys!!!
Info: 78 f250 d44. Stock knuckles (5 bolt, not 6). Moog BJs. 1 ton high steer kit from @4wheelsupply and high steer arms from him as well.
NOTE: Do not reply unless you have this exact same setup and your knuckles are also painted red.
After posting the attached picture on another forum build thread, someone had this to say:
EDIT: Found someone on Pirate who says highsteer will make BJs not last very long. That crossover would be more optimum for better road manners.
Some Joy-Bubble-Popping Knucklehead on Jeepforum.com said:You're making nice progress. Just keep moving forward.
Looking at those steering arms, I'd suggest you consider running the tie-rod on the knuckle (under the springs), and just do cross-over steering rather than full high steer. Running full high steer on those arms is going to impact your turning radius unless you run a much longer than stock pitman arm. Running crossover would allow you to use the shorter hole for the drag link and keep a tight turning radius.
I also don't like the idea of full high steer on a d44 without upgrading to something like the Reid knuckles.
