Nissan11
- Nov 29, 2005
- Marston, NC
I have an old galaxy 959 that I had 'peaked and tuned' by a CB shop near Fayetteville last year. I finally got around to mounting it in my truck yesterday. I mounted a new firestick II to the top of the bed rail behind the cab with 1/3 the antenna sticking above the top of the cab. I have struggled and struggled to get the SWR meter to within an acceptable range. With the coax cable going straight from the radio to the antenna and the antenna in my hand held above the top of the cab I get a very low reading which barely measures on the meter. With the antenna anywhere else on the truck I get readings around 3.5.
I tried grounding the aluminum antenna mount with a wire which made no difference. However, intetestingly when I took the plastic isolator from the top of the mount and moved it to the under side I got fairly consistant readings of 2.25.
This does not make sense to me since my understanding is the antenna is not supposed to be grounded to the mount. Can anyone offer any suggestions for ways to get a better reading?
Also, the tip of the antenna is screwed all the way down. The further out the adjuster screw is the higher the SWR reading. If I put the rubber cap back on the antenna the meter jumps from 2.25 to 3.5 which also does not make sense to me
I am attaching pics of the antenna mount.
