homemade toyota driveshaft help.
khwrx
lincolnton nc
ok got a 85 yota with duel cases, now its time to do my driveshafts. i looked on pirate bout making them, is there any place around the hickory area any suggest to get the steel i need. i know of benco , just dont want to buy 20 ft sticks and only need 3 or 4 feet. any help with steel suppliers and the building of the shafts , please chime in .
call budbuilt and get some square tube
Mr.Thickshaft
from my time in the field square is tha cheap way out cause if your on a climb and ya weight is on ya shaft the bumping of the square tube will grenade a joint or pinion i run 3/8 shafts front and rear on my yota if you need help on material pm me cause i got agood connection on that stuff:driver:
