Honda Engine crank holding tool dimensions?
SEAIRESCUE
SO Pines
I am currently in timbuck too, out of country, and need to fix the timing belt on a 1997 Honda Odyssey engine. I have no way to get the tool but I can have one made. What I need is the outside dimension across two flats of said tool. Anyone who has this hex tool and would kindly mike that dimension for me would put us back to driving instead of walking. A simple reply with the number is all that is needed.
Thank You,
Bill
KIR2111 The Swampfox @ 1975
Veteran
Don't know how far in BFE you are, but you can order them online for $20-$30 in case that's cheaper than having it made. Just make sure the clearance hole in the middle will clear your 19mm socket!
