I got a 97 honda Fourtrax 300 4x4. I am having trouble getting it to start with the electric start. These are the symptoms of what I got going on and have tried. Any ideas? Thanks in advance.
1. Can use kick start and four wheeler runs fine.
2. Had battery tested at 2 different places and said it was fine.
3. Charged battery on trickle charge for 8 hours
4. When I turn the key only oil light comes on, neutral does not. Its in neutral.
5. Periodically neutral fades on then goes back out. (like battery is low)
6. Can cross the started solenoid and it will start normally
Now the battery should be fully charged, no green light(neutral), turn the key press start and nothing happens. Will kick start and run fine. I think there is a pwr drain or something. Starter seems fine b/c it works when I cross the solenoid.
Let me know of anything I can try, last resort before having to take it to the stealership.
