Cherokeekid88
- Jun 30, 2007
- High Point, NC
So my 3 year old Mower started acting up about 3 weeks ago. It would act like it was going to die on me with fresh gas in there. Finally wouldn't start. It would start for 2-3 seconds and then shut off. I took the carb off and cleaned it, put all the gaskets backs in correctly and started up fine and would run but would idle extremely high. After a quick search, I realize it has something to do with the governor. I held the top of the arm in place while I adjusted the bottom end that is attached to the spring. Can see the tension slowly go away, where there is actually slack and it still runs high.
As I was taking the carb off, I am sure I probably hit one or both of the linkages for the governor, but figure I could just readjust to get it running normal.
Any ideas? Will try to take some pics when I go to lunch.
