how can I fix speedometer?
Dwayne96
Concord
have a 84 chevy 4x4 truck with a 4cyl. cummings diesel, 93 NV4500, & 3.42 gears. after completing this truck noticed the speedometer is 10mph slow. any ideas how I can fix it so speedometer is right? thanks!
you are going to need the right speedo gear...but I doubt you have a cummings motor in there ;)
Usually each tooth is worth 2 miles per hour. So you need it to turn faster. So subtract 5 teeth from the one you have should tell you what you need.
thanks for the info. were is the best place to get a new speedo gear?
