How do i run a toyota ps pump on a 16 valve?
89xjnc
julian nc
Bought a 16 valve to put in a samurai im building am going to be running a toyota ifs box with hydro assist on toyota axles. I would like to run a ps pump from an ifs toyota truck but cant find much information on it. Anybody know how or done this before?
just get you a good tc pump. PSC has the bracket. But I think one of the companies used to make a Toyota pump bracket but I can't remember who.
First go around with mine I had someone install Toyota box and pump on my 1.3. He modified the Toyota bracket and tensioner to fit the 1.3. When I went hydro assist, the Toyota pump wasn't adequate and I bought the Trail Gear TC style pump. I think I modified the already modified bracket to fit that pump. When I swapped to the 16V I just bought the TC style mount.
Ok thanks for the input guys. Think im going to go with a tc style pump and bracket from low range. Now i need to figure out the hoses
Ok thanks for the input guys. Think im going to go with to go with a tc style pump and bracket from low range. Now i need to figure out the hoses
Mine is the whole trail gear Toyota kit. Pump, lines, and ram.
I already have the ram, steering box, hoses from box to ram, and a filtered oversize reservoir. Just need to get the pump and hoses from pump to box situated. Should i run a cooler? I have one laying around, i would just have to figure out the hoses for it also
Put the biggest you can fit, and mount it in front of radiator so you get air pulled through it.
Just make sure to keep it below the reservoir height.
Ok thanks for the input. Do i just run the cooler in the return on the way back to the reservoir?
