95xjguy New Member Joined Aug 27, 2006 Location Ft. Bragg Aug 27, 2006 #1 How do I figure out whether or not if I have the 8.25 or the 35c on my xj with the 4.0, ax15, non-abs, and 95 model SE
upnover Grumpy, decrepit Old Man Moderator Joined Mar 20, 2005 Location Morganton NC Aug 28, 2006 #2 I think, but not sure, you should have a 35. But, look at the rear of the housing. If you have a plastic fill plug with a dana emblem on it, you have a 35 if not then I guess thge 8.25
jeepercreature New Member Joined Dec 7, 2005 Location New Bern, NC 28562 Aug 28, 2006 #3 should have a casting number or will look like this. ( ) The shape is different. Do a search, find pictures, then compare.
IRoKRubi New Member Joined Jul 20, 2006 Location Triad Aug 28, 2006 #4 Chrysler 8.25 Ring Gear Diameter: 8.25" Ring Gear Bolts: (10) 3/8" x 24 LH Cover Bolts: 10 Yoke / Pinion Spline: 1.626"/27 1972-2000 1/2 Ton 2wd & 4wd Rear Some Jeep Cherokees and Dodge Dakota / Durango Model 35 Details: Ring Gear Diameter: 7.562" Ring Gear Bolts: (8) 3/8" x 24 RH Cover Bolts: 10 Yoke / Pinion Spline Count: 1.375" / 26 1984 - Up Jeep Cherokee, Comanche 1987 - Up Wrangler
RenegadeStang Well-Known Member Joined Mar 3, 2006 Location Statesboro, GA Aug 28, 2006 #5 Check this: Diff ID With a non-ABS XJ, you could have the 8.25 or the D35. With an ABS XJ, you would definitely have the D35.
IRoKRubi New Member Joined Jul 20, 2006 Location Triad Aug 28, 2006 #6 also remember that in some select years / package configurations (towing package). . .had D44 rears. . .
getstucksome Well-Known Member Joined Nov 7, 2005 Location Charlotte/Mt. Holly area Sep 4, 2006 #7 ^ a 95 shouldn't have it i don't think. IIRC 87-89 were the only years that got the rear 44 with the towing package
