GotWood
Sayer of Fact
- Jan 12, 2007
- Maiden, NC
I broke the original then decided to cut it apart to see how it worked. That was a couple years ago. How do I order the correct one from Amazon?
No key way in the taper. I'll look up the chart stuff in a few.Looks like a Jacobs taper. Is there a key way?
Measure the two ends of the taper, see if it matches with a Jacobs taper chart, go from there. You should be able to find a cheapie Chinese chuck like the one that came on it, a good one will cost $80-150 (or more) and that's probably way overkill for that machine.
This was the kind of answer I was looking for smart ass (@Jeff B )The adapter looks like hell. With that much surface rust, it may have trouble wedge mating to the chuck. Ftr, there isn't supposed to be a key. It's a friction fit based on precisely machined tapers locking together when you put pressure on them. If you extend the quill, you'll probably find an oblong hole going through it. Take a metal wedge that you can grind out of 1/4" flat bar and drive it in that hole. The adapter will pop out. It's going to have a Morse taper, probably MT2 or MT3 on the quill end, then the Jacob's taper on the other. They're cheap. Go ahead and order a new one with the chuck. The taper may be printed on the adapter.
Yep there are some decent Chinese chucks out there for a 1/3 of the price of a new Jacobs and with very little run out.Now would be a fine time to go keyless, too, if you're so inclined.
