Tradarcher
- Mar 20, 2005
- Creedmoor, NC
For posterity's sake or in case someone has the same trouble one day. Tranny was shuddering when at neutral throttle when going up a hill with TC locked up. Would also shudder when applying "passing" throttle on the highway with TC locked up. Had to punch it to unlock TC to get it to stop. Had a little occasional "bump" from motor when idling at a stop light. After having the fluid and filter changed I did some net research and then had my mechanic hook up the code reader. No CEL but the ECM was reporting missing from a cylinder. Problem rolled with a coil pack so it was replaced. No more shudder. Apparently any missing that resulted from the coil pack was absorbed by the fluid coupling when the TC was unlocked when it was locked and under the most the most strain it would miss causing it to be felt through the drivetrain.
