- Mar 24, 2005
- Stokesdale-Greensboro
I had a copper pipe burst here, temporarily fixed it with a section of auto. heater pipe and some hoseclamps.
I'm looking to see if I can do the permanent fix maybe this weekend, but I can't figure out how the copper pipe is sealed to the PEX pipe. I have like an 8" copper section soldered to the outside spigot. Inside the house, it looks like the PEX supply pipe is just slid in the inner diameter of the copper pipe, maybe a tight fit, but there's got to be more than that
Plan A would be to remove the entire copper section and solder a new one to the spigot.
Plan B is to cut off the split section of copper pipe and solder the spigot back to the 5" or so that is left. I'm not sure if that is do-able, it might be too short.
Plan C involves calling a plumber or someone who knows what they're doing.
Plan D is do nothing and see how long my temp fix lasts
Well, off to shop vac water out of the basement...
. My temp. fix (with hose clamps) seems to be holding just fine, but it is pulled about 6" out of the house so will need to be fixed eventually.
