Clubbs
- Jun 15, 2008
- Blounts Creek
Put 262k miles on the Cummins. It's tuned and deleted, but otherwise the engine is stock. What's the consensus on in tank lift pump life?
Figure I got to be near the end of the factory pump's service life, and would rather be proactive instead of stranded somewhere with a dead pump. Are the FASS or similar lift pumps worth an upgrade over stock or is it marketing hype?
I'm sure it depends on if I add more power stuff so let's assume it will eventually get a bigger turbo and injectors when the factory ones give up, but not big enough to stack cp3's.
