I'm going to do a spring over on a yj with wagoneer front springs and a 9". I'll be running 37" irocs, and comp cutting the back. Will this be enough lift, or will I need a taller spring? This is my first yj build
Hope it wheels like it should when I'm though. I'm going to run ford radius arms from a 79 ford on the front with 12"/ 2.5 saw a ways. Turns out the frame on a yj and 79 ford are the same width, so all I've got to do is figure 6" foward and weld them on. Also using an astro steering box.
