JL Marvin
- Nov 2, 2008
- Union Grove NC
I have a 89 chevy 1500 ifs truck, 6.2 diesel and 700r4 Trans. I'm wanting to swap the 700 for a sm465, needing to know what left hand t case will bolt up ect. Thanks
Left is driver's side. Being an 89, it's a driver drop front IFSBy left hand case, do you mean passenger side drop transfer case? If so an NP205 from a Chevy will work.
Pretty sure they used the 465 up until the mid 90s. Probably grab a 241 with the correct input spline count.
And clutch pedal, maybe steering column, flywheel, master/slave cylinder, etc.Left is driver's side. Being an 89, it's a driver drop front IFS
^^^And clutch pedal, maybe steering column, flywheel, master/slave cylinder, etc.
It'll be a ton of work. An nv4500 would make it a little more worth it.
