There are plenty of pictures around of bob and dovetailed beds but I couldn't ever find a clear thread on how it was done. Hope this helps out anyone else.
Materials
-Rotating laser Level
-5 cut off wheels
-2 sawzall blades
1st. Decide I decided how short I wanted the bed to be. I chose to take out 14 inches, this way the end of the frame rail would sit directly behind the license plate.
The last section (tailgate, and lights) will be cut off first. The cut line on this is not directly behind the lights because I want to keep the structural supports built into the bed on the inside of the corner. measure from the front bed rail to the first cut line just past the inner structure of the bed, then mark the next point the length that you want to cut out. Mark with tape on both sides.
Now take the laser level and mark on the bed floor and up the inside walls, making sure that your laser is hitting the marks made for the cut on the outside.
Now cut. I found an angle grinder to be easier than the sawz-all due to less vibrations.
Materials
-5 cut off wheels
-2 sawzall blades
