Google something like "gear ratio calculator tire size". There are lots of online calculators where you can entire two tire sizes and a gear ratio or whatever and will calculate a difference... Just poke around and see which of them output what you actually want, because theres tons of them out there to choose from. As long as you know the factory ratio you're comparing to, you're good to go. You've got two ratios, and two tire sizes, so if all you care about is comparing shaft RPM or engine RPM or whatever, it's quite easy because nothing changed but the diff ratio so you can neglect everything else.
I usually just use Excel and some math and do it myself, but that depends on your comfort level with ...math.
