Four-Runner
Member
- May 15, 2015
- Durham
I have a 89 Wrangler with a 258 with Howell TBI fuel injection conversion (installed for several years). It has been cutting off going down the road recently... when I try to restart it the fuel pump is not running when I turn the key, after sitting for some time it will restart and run down the road for a bit before cutting off again.
I checked the fuel pump fuses in the harness, and checked that I'm getting battery power to the relay with the key in position 2 & 3. I replaced the fuel pump relay and that was not the issue, seems like the ECU may not be sending power to the signal terminal of the relay or maybe a wiring or grounding issue?
I'm getting beyond my abilities, any thoughts?
May be time for some help... any recommendations for a shop that is familiar working with Howell/older GM TBI setups?
Appreciate the help.
