jds97Wrangler
- Oct 19, 2008
- Mccleansville, NC
I'm sure this question has be asked a hundred times.
But anyways here goes the PO of my TJ welded a new lower control arm bracket on my current D30 and I believe they put in it on in the wrong location. In order to get my caster right i have to have one lower control arm almost 3/4 inch longer then the other.
I could cut the bracket off and reweld it but I would rather just replace the axle to make sure I fix the problem. I want to go with a HP. What years have the correct axle. Is it the grand cherokee or the regular cherokee? That has the axle I need. I don't care about the axle ratio becasue I am regearing to 4.88 this month.
