Whats the different other then just having more ground clearence for rocks? i know alot of the cherokee have them stock and was going to get a HP D30 out of one and put it in my 95 Zj, is there anything special i have to do to swap the HP D30 in?
It's not just a theory and having the d-shaft that much higher is a huge advantage. I've seen quite a few front shafts get a nice dent in them and subsequently twist into two pieces. Unless you carry spare front driveshafts with you, it can potentially save your weekend wheeling trip. You don't have to wheel balls to the wall to slip off a rock and damage the driveshaft. My .02.About the only advantage I see to HP is that in theory it is stronger then a low pinion because as other people have said it it runs on the drive side of the gear tooth.
I didn't mean anything by my theory comment. Yes running on the drive side is stronger it is not theory it is engineering fact. As for the ground clearance yes having the drive shaft up 4" inches is nice and has its advantages. But you do not gain differential ground clearance with the HP that was the only point I was making
uhh.....duh....
IMO it's worth it if you're planning on a regear anyways or can find one already geared to what you want or have. However, I don't think it's worth it if you're already running the gearing you want and the LP30 is still working.well i dont plan on doing that much hard wheellin. but i see that over all it looks like the HP D30 is the stronger axle and is worth tryin to get one
Food for thought: The HP is stronger when you are driving forward, and more weight is transferred to the rear of the vehicle. The LP is stronger when you are backing up, and more weight is transferred to the front of the vehicle.
Since we are all typically trying to go forward over obstacles, the advantages of an HP axle are usually in play. But when you are in a tight jam and trying to back out, keep that in mind. The reality is that you don't see LP axles blow out ring gears all the time going forward either.
