TheZenTree
- Mar 20, 2005
- Central KY
I'm working on putting together steering for my HP44 and I noticed that the stock tie-rod has a bend in it for what looks like diff cover clearance. I don't want to run a stock tie-rod because only one end has a removable TRE, so I need to make something that'll accept two TREs.
Can I just use a piece of straight tube (and what kind of tube should I use for this and the draglink?) or do I need to put a bend in it? I'm sticking with the stock diff cover for now.
Also, for the TREs, both should be the same thread (as opposed to one right hand, one left hand), so the toe doesn't get all screwed up, right? Adjusting it should just be a matter of loosening the jam nut, and turning the TRE in or out, assuming the tie-rod is cut the right length?
TIA
TIA
