So when I first got my humvee it burnt up the generator, so I switched to an alternator set up, then I burned up some glow plugs so replaced them, although I went cheaper knowing these smart boxes can burn them up. Few weeks ago I’m going to crank the humvee and it just turns over and over and puffs some white smoke out of tail pipe. This was an indication of bad glow plugs before, knowing I went cheap last time, I ponied up this time for some. Installed and it fired right up.
About a week later, I ran into same issue, motor turns over but doesn’t fire and white smoke. I decided to run a manual bypass for the glow plug controller, a write up I had found. This didn’t solve my issue. Still just turns over and puffs white smoke.
It’s the 6.2 non turbo diesel engine. Anyone with any insight? Or any “local” shops that work on these things
