rockcity
everyday is a chance to get better
- Apr 10, 2005
- Greenville, NC
Goodman is a good unit. Goodman is one of the top manufacturers in the US and supplies a majority of the parts for the other names (Trane, Carrier, etc.).
Trane is good, but isn't top quality until you spend $$$$ on the top shelf Trane units or get commercial units. Cheap Trane units are the same as Goodman, Armstrong, etc.
Only complaint I've heard from Goodman is the fan is a little noisy. So, if its right outside of your bedroom window, maybe look for a unit with less db. The spec sheet should list operating db to compare. My Armstrong was quite, quieter than the Trane I replaced it with.
Do you have a split unit (compressor outside, air handler inside) or packaged heat pump?
