Rich
Asshole at large
- Mar 17, 2005
- Central PA
In our house, we have a oil-burning, forced-air heating system. On the main floor, there's also a free-standing coal stove, which we like to use. Problem is, when we run the coal stove, the main heating system never kicks on, so the basement and a few rooms (like the bathroom off the kitchen) are very cold.
I want to be able to turn the fan switch on the thermostat from auto to ON and have it circulate air around, which will take care of the issue.
Last year, I replaced the old-school dial thermostat (2-wire) with a programmable one that works for any system.. heating, , heat pump, furnace, etc.
The wire going to the t-stat from the furnace is 5-wire, I hooked up a third wire to provide voltage to the new t-stat, so that's good, but I'm not 100% what I need to connect on the PCB of the furnace and then to the t-stat to enable manual fan control. (Currently, when the 2 wires on the t-stat get continuity, it starts a series of events... the oil unit kicks on, heats the furnace, then once the temp is up high enough, the blower fan engages and starts blowing warm air)
I'll take some close-up photos of the PCB and the schematic label on the furnace.. anyone think they can help? (I'm sure I can handle the t-stat hookup, the instructions were quite simple for that)
