Blaze
The Jeeper Reaper
- Aug 9, 2005
- Wake Forest, NC
So the system in my house needed replacing. The coil went out and burned up the compressor so I went ahead and replaced all of it since it was 17 years old anyway.
The old AHU was dirty but the heater pack and fan still worked great. I did not see the need to trash it, especially since my garage has air conditioning and no heat. See where I am going with this?
I removed the coil section and just have a box with the fan and heater now. I want to wire it up to a switch so that I can turn it on and just have it as a constant on heat/fan setup in the garage. When it gets too hot, just cut it off.
Or maybe wire it to a cheap thermostat so it can regulate as well as blow air?
What do you guys think? It is a 2.5 ton Carrier unit.
Here's the panel inside.
