Fabrik8
Overcomplicator
- May 27, 2015
- Huntersville
A few recent threads got me thinking about this again, and the recent cold snap has got me second guessing my otherwise brilliant plan for the future.
Have a gas pack in the yard. Appears to be 2001 from the serial number decoders, and has already been repaired a few times. It's a Bryant 3.5 ton unit, gas furnace and A/C. Single zone, single thermostat. Seems to short-cycle, which is not surprising given the tonnage in Climate Zone 3. It intuitively seems like it's oversized for the house.
I've been told by HVAC people that it's at or above the expected lifespan, statistically speaking. Those people may want to sell me shiny new HVAC systems though, so maybe grain-of-salt.
House is 1880 sqft, built in 1989. 1400 first floor, 440 second floor I think. Crawlspace, encapsulated. Unconditioned attic space adjacent to 2nd floor bedroom.
All ducting for 1st floor is in crawlspace. 2nd floor ducting runs between the closets on the 1st floor, then into a junction box in the 2nd floor attic before splitting to the bedroom and bath. Duct sealing is lousy. 2nd floor is usually always hotter than 1st floor, because furnace heat rises in winter and south-facing solar heat rises in summer.
So, here's where my head is at: I need zoning. I need more than one thermostat. I need new ducts. I want to get rid of the ducts in the attic, if possible.
There's a few options I've thought of:
But, I'm apprehensive about mini-splits in cold weather as my only source of heat. I know many are rated for 100% heating down to 5 or 10 or 15 degF, but I'm skeptical of that.
Does anyone have other options, or would like to weigh in on the options above?
- Multi-zone mini split system(s). Maybe concealed ducted units for the 1st floor rooms, or a bigger ducted unit with multiple outlets to distribute to 1st floor rooms. Daiken makes a multi-output unit with electric dampers on each output, kinda cool. 2nd floor would get a ceiling cassette or something like that, because it's pretty well suited to that. Could remove all existing ducting in the crawlspace and attic, and replace with well-installed ducting in crawlspace as needed.
- Smaller gas pack for the 1st floor (prob 2.5 or 3 ton, depending on calcs), with mini-split for 2nd floor. Could remove all existing ducting in the attic. Optional replace crawlspace ducting for better quality, air sealing, and age deterioration.
- Shawn's idea, putting a traditional split unit in the crawlspace. Would need to keep ducting in attic space for 2nd floor, or could still use mini-split on 2nd floor only.
