YJJPWrangler
- Jul 19, 2005
- Charlotte
I have this mount.
I have a hydraulic ram with heim joints on either side. Obviously, the heim joint is not as wide as the mount. I'm thinking I need some some spacers but I don't know what kind to get. I've found several that are labeled as misalignment spacers. Would something like this work?
1 to 5/8 High Misalignment Spacer Stainless Steel 2 5/8 Inch Mounting Width
Also, on my tie rod mount, the bolt that I have that fits the clamp on style mount(from Ruffstuff) has a smaller diameter then the heim joint. Is there anything I can do to "sleeve" the bolt so it doesn't rattle around in the heim joint?
First time dealing with hydro assist so bear with the questions.
Thanks,
Zack
Thanks,
Zack
