hydro steering issues please help??
zac attack
Member
Spartanburg sc
I have a double ended ram set up.. and my problem is... I can turn the wheel and the tires will turn but will slowly try to turn back even while I am still turning the steering wheel. .. I know something is evidently by passing my question is what?? The orbital? Or the ram it's self? ? Do orbitals go bad??
Steering valves can do some weird stuff when they go bad but first make sure you have the plumbing correct. The ports are usually marked p= pressure line from pump. T= return to reservoir and the others go to the ram.
BUCKEYE PERFORMANCE INC.
828-779-2242
