ProbablyBroke
does not torque to spec
- Nov 7, 2012
- Reidsville
Pictured is my most feasible spot.
As close to the pump as you can get it while keeping a good straight'ish feed. Wrap lines and even the resi in DEI ReflectaGold or similar heat wrap. I mounted mine in that same spot near the master in my last Yota rig. Lots of heat right there from the engine. It worked much better once I heat shielded some stuff and mounted it closer to the pump.
Slip on heat sleeve is a lot easier to use than wrapping lines with anything.
