Croatan_Kid
How's your hammer hangin'?
- Nov 4, 2007
- New Bern
So, a while back, I bought a Detroit Locker from a buddy. He said it was for a 14 bolt and I figured I could use a spare. A few months go by and I think about selling it, so I check it out.
The cross shaft pins are a smaller diameter, but the entire center section is larger overall than a 14 bolt. I verified by trying to fit it to an empty 14 bolt carrier and measuring 14 bolt spider gears. Also, instead of having 30 spline side gears, these are 16 spline. It IS, however, a lunch box locker, just like a 14 bolt uses. I threw away the box it was in because it had gotten wet and was falling apart...therefore, any part numbers are gone. There aren't any on the unit itself. Also, I had a busted 14 bolt Detroit from my K30 and the side gears WILL interchange, but it obviously still won't fit the carrier.
The axle diameter use for the 16 spline gears appears to be about 1.33". I just eyeballed it with a measuring tape.
Now then, from everything I can find only the 14 bolt, Rockwell, and possibly a very, very old Dana 60, and the Easton axles use a lunch box locker.
I need some more in depth information so I can figure out what this thing is! It's brand new!
