I need a driveshaft shortened
Fleetpride on 321 does good work,I think they $65 or $70.
ccc, it's over by the little dairy queen walk up.
bit of a drive, but I gotta recommedn Dave at Oliver's, he is a board sponsor and a sponsor of ECORS, does great work and is a stand up guy!
A little drive but you wont get better work done at a fairer price!!!!
HAve you considered doing it yourself? It's not rocket science.
1. Cut the weld at the yoke with a grinding wheel untill you can see a hairline crack all the way around.
2. Beat out the old yoke.
3. Cut the length exactly straight. This is the only hard part. I use a hose clamp and portaband. The hose clamp acts as a true line.
4. Tap the yoke back in and weld it in place.
I did mine in my Jeep ,just took my time and doubled checked everything.Mine worked out fine,
If you want it balanced put a pint of oil or transmission fluid in it before you weld it back shut too. An old street rodder told me that trick and it works pretty well.
84cucvk-5 i really dont think its in good taste to make fun of the handicap its not like they had a choise you on the other hand seem to be uninformed about life and people
