I want to run 35/36's on my chevy....how?
MrHman
Joined the Band
Banned
Wrightsville Beach/ Chapel Hill
I want to run 35 or 36" tires on my 86 chevy. Right now it has a 2 inch suspension lift with 33's.
How much lift would I need, would a 4" be enough or would i need a 6"?
or i could do a 3" body with the suspension I already have
with a suspension lift, how high can I go before i have to worry about getting a slip yoke eliminator and a new drive shaft.
i've seen 38's run a 4 inch lift/no body without rubbing just depends on how much you like your sheet metal:popcorn:
yes its a K10 shortbed
I like my sheet metal, so i'm not quite ready to bust out the saw. so should I get a 4 or 6 inch?
Someone told me that a body lift for it is bad because it will flex the body too much....that true?
I'm working on building up my k5 and plans are to go with about 4" and liberal fender trimming to run some 37"s or so.
with 4" lift 35's will clear if you cut rear of front fender about 1"
