ProbablyBroke
does not torque to spec
- Nov 7, 2012
- Reidsville
Since it's been getting below 40 degrees the last few months, I have been avoiding driving my 1995 7.3 f250 because it was leaking about an 8 inch spot of engine oil on warm up. Leak was coming from oil cooler. I did the research, and ordered the big o rings and gaskets to do the cooler.
Today I pulled the oil cooler and cleaned everything. The oil pressure relief valve slid out, which I wasn't prepared for (it is not c clipped version). So I decided I would look at the schematic and install everything tomorrow. Well, the oil pressure relief valve isn't the issue. My issue is, I have been driving this truck WITHOUT an oil filter bypass valve. I wasn't aware. I have put 4K miles on it in a year and who knows how long the bypass valve was missing prior to my purchase. My understanding is that essentially, my oil has never been filtered.
A new oil cooler housing is 344$.
Does anyone know where to source just the bypass valve components? Does anyone have a good oil cooler housing? What steps would you take to ensure the truck isn't doomed?
@mysterync @Tim C @frankenyoter
Any and all suggestions welcomed
