CTRaceWorx
- Aug 23, 2007
- Charlotte
As you have seen posted we are the only east coast Ballistic Fabrication Distributor. Along with being a distributor we will keep several items im stock. This is a breif list believe it or not of what will will have on the shelf.
We will be the only shop that I'm aware of on the east coast to stock high steer arms, brackets, tabs and joints at all times.
-Dana 60 High Steer Arms
-Dana 44 High Steer Arms along with every option avaliable, spacers, studs and all
-Chevy TRE Kits with tube adapters
-3/4 Chromo Rod Ends
-7/8 Chromo Rod Ends with both ball sizes
-Several Different High Misalignment Spacers
-Safety Washers
-All 2.63 and 3.0 Weld on Joints
-The NEW 3.0 with 1.5 Shank Forged Joints (I, myself will offer a lifetime warranty of the forging of this joint from breakage)
-2.63 with 1.25 Shank Forged Joints with all Bores
-2.63 Forged Poly Bushings with all shanks and bores
-Several Lower Link axle Brackets, all Degrees
-Several Link Brackets, too many to list
-About a dozen different types of shock tabs amounting in over 120 different individual tabs
-Almost every single different Rockwell bracket offered
-Every Jam Nut and Tube adapter to match for round and square tube.
There are more than 500 items that will be on the shelf and the list will continue to grow!
We should receive our first shipment around June 19th.
If you have any suggestions on what you would like us to stock please let me know and Ill get them on the next shipment.
-Safety Washers
