Calvins Cherokee
Member
- Mar 21, 2012
- Rutherfordton N.C.
Just wondered if anyone knows the best way to fab bolted tires and on what terrains they work best on...Been wanting to try some but didnt know if it was worth the work...
The hill shooting buggies are running tires now. They say it increases traction in the dirt., with wheel speed it doesn't look to hurt too bad on the rocks.
They drill the hole through the center of the lugs. Put a bolt with washer through from the inside with a washer & but on the outside.
Then run tubes inside the tires.
Sent via telegraph
Years ago when I was actively caving 2 weekends a month, I used some tech-screws in my boot soles. The idea was better traction during approach hikes along wet, muddy trails with lots of downed/semi-rotting timber to climb over. They worked great for that, but I found the screw heads made traction on rock almost impossible and destroyed my inner calf area when contact was made... pulled out my Leatherman & removed them in the cave that very day.
they did in the dirt anyway i did notice that the rock slowed him down.thanks for the vid paridise PWoffrd..those tires are gettin it done..
i think bolted tires are the biggest 'neck ass things you can put on your rig. they tear the shit outta the trail and really do nothing on rocks. if i see them on a truck I expect to see rebar handle shifters and square tube roll cages.
sumbitch'll foldDon't be hatin on my square tube roll cage. You know your just jealous.
A set of regular ass tsl's would work better than either of those options.
