fbpd227
Active Member
- Jan 12, 2007
- Smoky Mts. WNC- Sylva, NC
I am installing a deep trans pan on my 32 rh (999) and everything in the Mopar kit is self explanitory except for one peice? There is a small light green plastic peice which I can't figure out if it's for the pan drain plug gasket or if it is supposed to go between the filter and the drop bracket? There is no way to "center" it on the filter- so I IF it went there- how would you know if it was "centered" properly, or if it was obstructing the pick-up tube? Anyhow- THAT'S why I turn to the experts! HELP!
