Inner tube question
X2 on the 33. Will also eliminate the chance, of tube, getting a wrinkle in it. A wrinkle will wear a hole in itself. Blow the tire tube assembly up, [32-35pis] then let all the air back out. make sure the stem is centered, then inflate to desired psi. Best way to eliminate wrinkles.
Smaller tube.
Tubes are rated mainly by their width, not height - b/c the height varies susbtantially depending on how much air you put in it. Really you need a tube rated for a 10.50 tire.
And yeah you don't want that thing to get wrinkled and pinched, esp when running aired down.
