ManglerYJ
- Mar 20, 2005
- Lexington, NC
Does anyone know for sure if your vehicle has to have brights (hi-beams) in order to pass inspection in NC? For some reason when I installed a new steering column in my YJ, the new column was meant for a vehicle with a floor mounted dimmer switch and the lights are stuck on hi-beams. I can easily switch two wires to make them regular headlights, but is there anything that says I have to have both?
I do also have off-road lights mounted to my windshield (talk about high beams!), so will those suffice even though they are on a separate switch?
Also, is there anything that says where a horn button must be located, or just within reasonable reach of the driver? I was thinking of just putting that button on the dash. I know they test the horn when they inspect the vehicle, that's why I need to put a horn button on.
Thanks in advance, and please.... no guessing at this. I can do that! I need to know for sure before I spend a bunch of time on something that isn't even checked for.
Horn buttons call be anywhere with reach of the driver. Kinda like broken windshields and tires, a judgment call on the part of the inspector.
