Interior swap in my MJ
NC919.4x4_XJ
Member
Holly Springs
Whats up guys, got a few questions for my dash/tranny swap in my MJ.
I have a 93 motor/trans/tc swapped in my comanche with the wiring hariness,
i have a few sensors plugged up and trying to get everything sorted out.
I am having troubles finding most sensor plugs and connections..
will everything most likely connect, or will i have wires hanging around?
Also, the tranny i have now is a auto, and the MJ was a manual..
where can i wired the shifting chord to the shifter? is there any easy ways?
and also what do i need to do about a plate to cover the hole for the shifter?
I am a little confused on what to do, and i need some help!
thank you.
Dont see a need to start a new thread. Thinking about doing the 97 conversion on my manche, Ive heard swapping the dash is a real pain?
Someone said I would have to swap a 97+ ecu and harness.
Any tips?
Any tips?
ecu, harness, the engine uses differenr sensors than your RENIX system, sections of the firewall will need to be patched or modified for mounting points as well as hvac box, seat mounts are different. its pretty labor intensive, do some reasearch on comancheclub.com, several builds threads documenting the conversion
the shifter floor plate is the same as on from an xj. so get it from the vehicle you pulled the shifter
i believe it is from the 93 donor XJ, but it doesn't fit at all...
i was thinking about going to the junkyard and maybe finding that matches...
just needed some opinion.
Any tips?
it is alot of work, alot of guys that i have seen on manche forums have taken 18 months to do it right, and
to get everything to work correctly. its crazy man.
