irok wheel size question
tkeaton
Master Velocipede Alchemist
Chattanooga
when runnin 39.5 iroks on 16" wheels, what width works best? interco suggests a 16x12....but since when have manufacturers been right?
pheery, werent you running this same tire?
You going to run beadlocks? I assume this is a trail only rig since you are going with Iroks.
DK
trail only, except for a few midnight runs through the neighborhood.....no beadlocks initially, will do weld on locks if i decided they need them
I'd say no wider than 10"... 8's with a wide weld-on kit like Rockstomper's
They need bead locks. Take my word for it. You didn't mention how wide the tire is? I'm running 36 X 13.5 on 10" rims.
I'm running 36x13.50 on 15x8 steelies...
sanded down the powdercoating where the bead seats...used a little bead sealer...and run 'em at about 6-7PSI on the trails...haven't lost a bead (yet)...
I do run the radials...but they still flex pretty decent:
Greg
I'd run a 8" wide rim with that tire.
