ProbablyBroke
does not torque to spec
- Nov 7, 2012
- Reidsville
I'm putting a fuel cell in the bed of my ranger. Cell is a plastic 10 gallon from summit with fuel fittings on the top. Has an aluminum pickup tube going from top of the tank to the bottom.
My plan was to use the in tank fuel pump from my oem gas tank in the bottom of the fuel cell. It'll require expert hose clamp application and some large diameter fuel line. My question is how do I SAFELY get the 12volt power and ground to the outside of the cell? I'm not opposed to drilling a small hole in the cell or running it under the the rubber gasket that mates the flange to the cell. My concern is chafing the wires, grounding the power wire and having an explosion.
Let's hear it.
Let's hear it.
