ISO an intermediate gear on a Dana 20 of 39t x 19t, YES 19 teeth? Transfer case from a Bronco
tonyb70
New Member
ISO an intermediate gear on a Dana 20 transfer case from a Bronco of 39t x 19t, YES 19 teeth? 2 of us counted them 8 times and there is definitely 19 teeth. a few teeth are chipped. an extensive web search cannot find this gear w/ this teeth combination for the dana 20. we are wondering that maybe the teeth are chipped(short of a bad driver) b/c someone has changed out the gear for the possibly correct 8-5-9/809293. history is unknown as it was loosely inside another vehicle w/ other parts. info from the transfer case; mfg date 7-19-74, serial 1985923, b/m 300 777-18, d3ta-7a195-cc, told it was a j-shift, c18-15-29. on the shaft of the gear on the outside has 18-7 and 22 stamped on case. i will try to supply pics if the site allows.
pics
I would call Novak Adapters; they are one of the most respected tech resources for these cases. Their entire catalog of gears for Dana 18 and 20 does not have this combination so I think you miscounted.
Something seems wrong, did you pull the gear and count teeth or spin it in the housing?
