i have a 76 cherokee that wont turn over and im about to spread napalm all over it to get some kind of fire.
i charged the battery and also tried to jump it off. nothing!
then i took the starter to a local parts house and tested it! works good at their place...yay.
i bought a new solenoid, and a few other parts for a quick tune-up for when it was running. after re-installing the starter, all i got was a hummmmmmm at the solenoid i just replaced. i tested all the wires and grounds. i took off the ground from the block and any other grounds and cleaned them for better connection.(just in case. couldnt hurt)
now i got the same thing..a hummm and a click.
wires to the starter are fine making good connection. battery terminals are clean and posts are tight. the only other wires that go to that area is the small one that clips onto the front of the solenoid and goes into a box on the firewall just above the solenoid. im not sure the name of that box, but its the only other thing that directly affects the starter.
what is the name of that box?? i gotta replace it anyway just to be sure.
any help is appreciated. any direct assistance would be helpful also if you wanna come to asheboro. ill buy the beer and maybe even feed you a decent meal
