- Mar 19, 2005
- Raleigh
Day 12 - FO' SHIZZLE
The Day 12 prize comes to you thanks to Oliver's Custom Drive Shaft and Welding Repair in Winston-Salem, NC. @Oliver's is a full service shop to help you out with anything to do with the running gear of your car. Offering new Original Equipment, Custom Drive-shafts for most applications, as well as a full line of performance and off road parts and installation. Check out their website or send a PM to Dave!
Today's winner will receive a pair of PRP Daily Driver seats and 4-point safety harnesses!
The Day 12 prize also includes a 2017 Uwharrie OHV annual pass, a NC4x4 Koozie, NC4x4 stickers, and a lifetime NC4x4 Subscription.
AND THE DAY 12 WINNER IS... POST #215 - PAT Ventures!
Day 11 - MERRY CHRISTMAS FROM THE FAMILY
Today's winner is taking home a fabricated heavy duty steering kit from Metalwerx Design & Fabrication!
Don't start the New Year all bent out of shape! Replace that bent up steering with a heavy duty steering kit from MetalwerX Design and Fab!
This kit includes:
- Two pieces of 1 1/2" OD 1/4" Wall DOM tube, cut to length and bent as needed to fit your application!
- Four @Barnes 4wd Heat Treated Chromoly Heims...3/4" Lt Hand and Rt Hand thread
- Four Weld-in threaded tube inserts
- Four Misalignment Spacers
- Four Safety Washers
- Grade 8 hardware with Nylock Nuts
The Day 11 prize also includes a 2017 Uwharrie OHV annual pass, a NC4x4 Koozie, NC4x4 stickers, and a one year NC4x4 Subscription.
AND THE DAY 11 WINNER IS... POST #133 - RHSCTJ!
Day 10 - ROCKIN' AROUND THE CHRISTMAS TREE
Today's winner will receive a disc brake conversion kit from Shawn Miller, aka @GubNi, at Lug Nut 4x4.
These kits contain most everything you need to convert an axle to disc brakes, including:
3/8″ thick laser cut brackets
DOM bracket spacers (when needed)
grade 8 anodized mounting hardware
new Chevy rotors
rebuilt Chevy calipers with steel pistons
semi metallic brake pads
new inner hub seals
caliper pins
rubber flex hoses
banjo bolts with copper washers
anti-rattle clips
Shawn offers kits for Dana 60s, 14 bolts, 10.25s, Eatons, and even Ford front Dana 44s and 60s. Check out his website for the full list or send him a PM.
Today's winner will also receive a 2017 Uwharrie OHV annual pass, a NC4x4 Koozie, NC4x4 stickers, and a one year NC4x4 Subscription..
AND THE DAY 10 WINNER IS... POST #93 - /dev/yj!
